Nitrous plug gap help
Old 03-05-2014, 06:07 PM
fatboyzcamaro's Avatar
Default Nitrous plug gap help
Hello fellows checking to see what gap are you setting your plugs at when spraying.
On motor I use tr 55 and gap them at .035
On 150 shoot what should I gap them at. I'm Using ngk 9 and ngk 10.
If I go up to 200 or 250 which way do gap go up or down.
Old 03-05-2014, 10:40 PM
Killer5.3's Avatar
I would run ngk BR7efs gapped @.030 on 150-175, BR8ef gapped @.028 for 200. The 9 may be a little cold for 250 depending on compression, your tuneup , timing , etc.
Old 03-06-2014, 08:56 AM
dekan513's Avatar
yep i agree with killer. i try to keep mine around .032 . but thats just what i was thought. but ive never spray a anything over needing a br7ef too.
Old 03-06-2014, 09:58 AM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
.030-.032, may want so consider a "BR" plug for the non projected tip, and may also want to go to a 6 or 7 heat range, especially for a 150 shot.
-Garrett
Old 03-08-2014, 10:27 PM
samsperformance's Avatar
BR7EF running .030 is the business, running 175 shot with 6 deg timing pulled and stand alone fuel system of C16
Old 03-12-2014, 09:49 PM
Thanks guys.
Quick Reply: Nitrous plug gap help
