Corvette P/R output adapter
Old 03-05-2014, 09:17 PM
AB6DO's Avatar
Default Corvette P/R output adapter
On my Corvette pressure regulator, I am using Russell #644020 adapter for the output to the engine. The adapter will slip in but does not seem to lock up tight. I am wondering if I am using the wrong adapter!
I will use Russell #644120 thread on quick connect when I get the right push in adapter.
Old 03-05-2014, 09:47 PM
ChevyOwner's Avatar
Try this one 640940
Old 01-08-2015, 10:02 AM
lvillene's Avatar
I am having same problem as AB6DO. I purchased regulator kit from Spedway http://www.speedwaymotors.com/LS1-Fu...Kit,41791.html
It has the Russell part number 640940, when I insert this part into outlet side of regulator it does lock, however I'm able to pull/push this line a bit maybe 1/4 inch. I'm thinking this will leak. Is this common or is it inferior part?
Old 01-08-2015, 12:39 PM
1964SS's Avatar
If I remember correctly that is normal.
Old 01-08-2015, 01:02 PM
lvillene's Avatar
Thanks for responding 1964SS. It's still got me concerned, I'll proceed though.
Larry
Old 01-08-2015, 08:57 PM
Project GatTagO's Avatar
Received 1,393 Likes on 879 Posts
I would not use those older style Russell connectors. There are several documented cases of them coming off and causing fires.
Russell makes a new style fitting that has a screw on rear lock. Those are excellent. Look for pictures and part numbers in my Cougar build thread. Link in sig.
Andrew
Quick Reply: Corvette P/R output adapter
