need help on turbo cam specs
Old 03-05-2014, 10:35 PM
01FireTurd's Avatar
Default need help on turbo cam specs
I picked up a slightly used cam wondering if it would work good with a single turbo 6.0
234/236
.601-603
112+4
When I calculate the overlap(11) I get the same as speed Inc's tu2 which is 236/236 578-578 112.5
Which I know there's a lot more than just overlap
Thoughts?opinions? Thanks
Old 03-08-2014, 12:53 AM
01FireTurd's Avatar
Old 03-08-2014, 09:39 AM
sbcgenII's Avatar
If your turbo has a good size turbine i would run it. Like you said it is almost the same as a TU2 cam.
Quick Reply: need help on turbo cam specs
