Coil Issues (passenger side not firing)
Old 03-06-2014, 12:05 PM
ATX LSX's Avatar
Angry Coil Issues (passenger side not firing)
Did a coil relocation, extended coil harness.
First issue was driver's side wouldn't fire due to INJ1 fuse being blown (passenger side fired at the time). Fixed that, now passenger side isn't firing.
None of the cylinders on passenger side are firing, manifold is entirely cold.
Checked wiring, it's good. Fuses are good.
WTFBBQ...
Anyone have any suggestions?
Old 03-06-2014, 12:18 PM
ls1_chevelle's Avatar
wiring isn't good LOL
Old 03-06-2014, 12:23 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Did you check voltage and see if you have any faults?
Old 03-06-2014, 12:26 PM
ATX LSX's Avatar
if it wasn't good, then why would they have been firing when INJ1 fuse was blown?
Old 03-06-2014, 12:31 PM
Jrclayton's Avatar
May i make a suggestion and suggest you make sure the grounds are all in place. My buddy's had the same issue when he redone all of his ****. Turned out he had a bad ground connection. Might be different for you but worth a shot
Old 03-06-2014, 12:34 PM
BLINGOLE's Avatar
i would start with, Does the pink wire have ignition voltage on the coils?
ATX LSX's Avatar
No I haven't... not an electrical engineer but I know how to extend a harness.
Old 03-06-2014, 12:53 PM
all Im saying is if the car ran fine before the coil relocate, the only thing touched is wiring... orr what else did you touch?
Old 03-06-2014, 01:24 PM
UNDER PRESSURE MOD
I'm not an electrical engineer either, but my point is, trace back the path of signal so see where it is that the break is. So if you're not getting spark at the plug, go back to the coil, check so see if the coil is getting a signal to fire. If not, go back to the harness for the 4 coils and check there.
Old 03-06-2014, 01:37 PM
stevieturbo's Avatar
Well..the results might indicate otherwise, and fuses rarely blow when wiring integrity is good.
So do you have 12v at the pink wire ?
How are you confirming you have a no spark scenario ? and is it all 4 coils on one side, or some coils ?
And are you sure all 4 are firing on the other side ?
Old 03-07-2014, 06:59 AM
skinnies's Avatar
exactly
Quick Reply: Coil Issues (passenger side not firing)
