could low oil level make starter continue to run
Old 03-06-2014, 07:21 PM
Jc803's Avatar
Default could low oil level make starter continue to run
So before, everything worked normal. Then all of the sudden on cold starts my starter continues to run. It's never the same amount of time either. Sometimes it's for one minute, sometimes up to 3 minutes.
But once the engine is warmed up, if i crank it the starter cuts off immediately. Nothing has changed, no new work done, nothing electrically has changed. The only thing i noticed is the oil level was super low. I refilled it and it cut off line normal but also it was still fully warmed up so i don't know if that fixed it
Old 03-06-2014, 07:35 PM
ULTIMATEORANGESS's Avatar
id check for codes. ive never had a hard time starting my car with low oil.
Old 03-06-2014, 08:24 PM
LS1Tech Sponsor
COSPEED2's Avatar
The oil leaking onto the starter will! That is likely why you have low oil. It can also short the starter out. Both things are bad.
Old 03-06-2014, 08:39 PM
Jc803's Avatar
No codes and no oil leaks. I just figured I'd ask because strange electrical things happen for strange reasons on these cars it seems. Thought maybe the low oil sensor might have something to do with it. A wild guess i know
Old 03-06-2014, 08:40 PM
LS1Tech Sponsor
COSPEED2's Avatar
Check the starter for oil contamination.
Old 03-06-2014, 10:04 PM
big hammer's Avatar
starter solenoid.
Old 03-09-2014, 07:08 PM
Jc803's Avatar
Replaced the starter. Problem fixed. Glad it wasn't a wiring or electrical problem
Quick Reply: could low oil level make starter continue to run
