how to convert from MAF to MAP
Old 03-06-2014, 09:41 PM
1988montecarloss's Avatar
Default how to convert from MAF to MAP
im going to be putting a turbo LM7 5.3/4l80e into an 84 cutlass and im wondering what ill have to do to convert the motor from MAF to MAP, ill be using a PSI standalone harness. my questions are, how do i wire the MAP sensor into the harness and where should i mount it? in the intake piping right before the throttle body? i know that ill obviously need a custom tune to run a MAP sensor and for the turbo setup im just wondering what i physically have to do to the motor to convert it to MAP, i also plan on using this MAP sensor:
http://www.efisource.com/shop/gm-sty...sor-w-pigtail/
Old 03-07-2014, 06:09 AM
Old Geezer's Avatar
The harness should already be wired for the MAP.........
Ask Jon, at PSI. He'll help.
Old 03-07-2014, 10:51 AM
Okay thanks!
Quick Reply: how to convert from MAF to MAP
