Need help ID'ing clutch brand
Old 03-07-2014, 06:59 PM
EGV00TA's Avatar
Default Need help ID'ing clutch brand
Just pulled tranny to get the stage 2 at Texas drivetrain done and debating to replace the clutch. Its not slipping or any issues with it. Its has these letters stamped LUK around pressure plate and this part # on the side 14188-2B04A.
Old 03-08-2014, 07:20 AM
Exidous's Avatar
If it's a Luk it is probably an LS6 or LS7 clutch.
Old 03-08-2014, 10:29 AM
SNLPerformance's Avatar
Take a picture and we'll see if we can help you identify it. If it is a single disc with a SAC style pressure plate see if the flywheel is flat or not... that's the easiest way to see.
Old 03-09-2014, 02:07 PM
EGV00TA's Avatar
Thanks for the help i think its an LS6 clutch but i have no choice right now but use this one. The trans repairs came out more than expected i fo still need a new slave and a speed bleed line for it how much do yall at SNL have these for its an 02 WS6 T56
Quick Reply: Need help ID'ing clutch brand
