cam swap quick question
Old 03-12-2014, 09:56 AM
redz96lt1's Avatar
Default cam swap quick question
I have a 96 lt1 Camaro 6 speed currently has slp cai hooker shorty headers full Magnaflow catback exhaust and 4.10 rear gears. I'm planning on doing a cc503 cam swap electric water pump and I'm wondering if I should upgrade to a 52 mm throttle body? I believe I read somewhere that the stock intake manifold can support a 52 mm. I'm wondering if this true and is it worth wild in upgrading the tb. I do plan on eventually going with Lloyd's le2 package in near future a year or two. Any advice on that would be greatly appreciate it.
Old 03-12-2014, 10:24 AM
BALLSS's Avatar
for just the cam swap only...you don't "need" a larger TB. When you do the "LE2 package" (assume heads and cam) than you can. I would have the stock TB bored to 52 vs buying a aftermarket one.
for just the 503 swap....I would invest in new springs before TB
Old 03-12-2014, 12:27 PM
93M6Formula's Avatar
My advice? Save up and do the LE2 package all at once, whats the point of running a CC503 only to pull it out a year later?
Old 03-12-2014, 01:18 PM
HellTeeOne's Avatar
A throttle body upgrade is not particularly necessary with either the CC503 swap or the full LE2 package. Just stick a airfoil on the stock tb and run it.
Old 03-12-2014, 01:20 PM
ahritchie's Avatar
^ What he said, I will add, save yourself some money and headaches by getting a STOCK TB bored out to 52mm, not an aftermarket one that give issues. Just paint it and put a fancy TB plate on it if you want it to look nice.
Quick Reply: cam swap quick question
