LS1 T56 vss hookup
Old 03-16-2014, 06:24 PM
iroc565's Avatar
Default LS1 T56 vss hookup
Has anyone hooked up the VSS to an autometer gauge. My car is and 86 camaro, so it never had the 4th gen PCM
Old 03-21-2014, 09:56 AM
onebad82z's Avatar
I run this speedo..
http://www.autometer.com/cat_gaugede...id=2807&sid=15
One wire from stock T56 VSS I have grounded to frame rail. Second wire runs direct to the speedo. Connect all other speedo wires as instructed by Autometer, program as instructed. Zero issues and accurate.
Old 03-23-2014, 05:49 PM
iroc565's Avatar
That what I did, but speedo did not work, I will change the wires around, could not get any direction on which wire was the VSS
Quick Reply: LS1 T56 vss hookup
