Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Downgrading GPS firmware
Old 03-18-2014, 09:22 AM
bigti99a's Avatar
Default Downgrading GPS firmware
This is not a huge issue as i do not use my GPS often at all as its so damn outdated. BUT when i got the car the seller gave me a firmware update. I ran it and now it says my map disk is incorrect. So is there any way to reset the NAV firmware back? Or to find out what map disk version will go with the firmware i have.
any help or info would be appreciated.
thanks.
Old 03-18-2014, 11:26 AM
heavymetals's Avatar
You cannot "go back".
Did the map disc work before?
Map discs are not compatible across the Cad platforms (thanks GM!)
Old 03-18-2014, 12:58 PM
bigti99a's Avatar
my original disk did work before. then i got the bright idea to go ahead and update. now it does not work. kinda sux that you can not undo the firmware update.
Old 04-08-2014, 09:23 PM
bdrussell's Avatar
Do you have the ability to burn a dual sided DVD? I'm running the Navteq 6.8 for a Nissan in our 05 V. That got my maps up to 2010 at least.
PM me for more info if you like.
Cheers
RustyNCA
Quick Reply: Downgrading GPS firmware
