Tick master cylinder adjustment
I'm installing a tick master on a 2000 Camaro. I've got my old master off and needing to know do I take the spring off the clutch pedal. I've seen some instructions say remove it and some don't mention it. The Tick instructions that came with it don't mention removing it so I called and Tick said you can if you want but you don't have to it's preference. Any other tips on bleeding and adjusting would be appreciated. Thanks in advance
