What can be done to a 10 bolt?
Old 03-19-2014, 04:04 PM
98Z28NMB21's Avatar
Default What can be done to a 10 bolt?
OK, so for starters I know there's gonna be a bunch of people on here that say it cant be done. So for starters Im running a G5x3 cam with intake and all supporting mods except heads at this point. I also do not have the cash to drop on a new rear and im wanting any and all ideas or past experience on how to help save my 10 bolt. Im not looking to ''Bulletproof'' it I just want to know what can be done that actually helps this things out under stress and the do's and donts. My car is a 6 speed as well and know that the T56 isn't exactly known for being easy on the rear ends. Thanks.
Old 03-19-2014, 04:07 PM
HCI2000SS's Avatar
I run a Detroit Trutrack in mine
Old 03-19-2014, 06:27 PM
98Z28NMB21's Avatar
Is that all you've got in it? and if so how dose it hold up to Stress?
Old 03-19-2014, 06:41 PM
alexus6798's Avatar
Best thing for now is keep street tires on it and nothing to sticky.
Old 03-19-2014, 07:17 PM
nascarnate326's Avatar
275 street tires, nothing too soft. Basically if you dump the clutch, you want it to spin easily, putting less pressure on the rear end.
Thats what I have done and so far no major failures.
Old 03-19-2014, 07:38 PM
SMOKNSS's Avatar
I put 4.10s in my old 7.5 with a TA girdle cover and never had any issues out of it when I had the t56 in my car. I ran Hoosier QTPs and then switched to 325/50 M/T ET Streets. The guy I sold it to just put a new pinion seal in it but has been driving with it with zero issues.
I never cut any 1.5X or stronger short times but LOTS of 1.7Xs and lots of street passes. As long as you don't side step the clutch on a prepped surface you should be fine.... just preload it a little and let her rip. That has been my experience.
Old 03-19-2014, 07:45 PM
Tolley's94z28's Avatar
The best thing you can do is to just be aware that it is a weak point and treat it as such. If you dump the clutch all the time, it's not going to hold up.
Old 03-19-2014, 08:16 PM
HCI2000SS's Avatar
Yes pretty much. I make about 550 rwhp/rwtq with drag radials, 4.10 gear, 6-speed, and so far so good loland a
Old 03-19-2014, 09:05 PM
duh
duh's Avatar
I had the same idea. I did a lot of searching for parts and ideas. I also came up with a $1200 price tag. That included studding everything I could, the LPW back brace (which I bought, but not the cover or installed), and the trutrac and axles. I also decided it would be money better spent to just jump to a 9" that will last a lot longer and require less money to upgrade down the road. If you really want to make a 10 bolt last, it's going to take $1200 before any labor. If you're curious you can pm me and I can detail everything for you.
Old 03-19-2014, 09:43 PM
98Z28NMB21's Avatar
Wow thanks guys, Im buying another 7.5 with 3.90s in it with a girdle, I hear that Girdles help a little.
Old 03-19-2014, 09:51 PM
98CayenneT/A's Avatar
I have 3.73 with a girdle and many dead hook street launches on drag radials with no problems, but I'm also a auto but know it will eventually go kaboom clunk
Old 03-20-2014, 01:33 PM
It's not mine! woo hoo!
demonspeed's Avatar
If doing the LPW cover with braces, I'd also suggest welding the axle tubes into the housing. Might as well throw new seals and bearings in there while you're at it.
Old 03-20-2014, 04:00 PM
Majestic9C1's Avatar
If you are good at welding you can fully weld the axle tubes to the center section, put on a rear girdle cover and maybe some moser 28 spline axles
Old 03-24-2014, 05:38 PM
VincesSS's Avatar
I had a mac cover, solid pinion spacer, welded tubes with my motive 4.10s. Quiet as a mouse after install. First launch at the track (1.8 60') and it started whining again and I'm only 400whp/tq.
If you can't afford a new rear end be gentle and just fix what breaks with stock parts till you can upgrade.
Don't look through these replies with focusing on the small glimmers of hope and ignore the many that have gone through this telling you it's a waste. They suck, they suck and they suck some more for drag racing, but hey it's your money and it's your mistake to make.
Old 03-24-2014, 05:49 PM
guppymech's Avatar
This is the absolute truth.
Old 03-28-2014, 05:36 PM
arock24's Avatar
Truth. I threw a T/A cover on it, and leave street tires on. Still running strong with 123k on it. Granted, I have an auto, but it's all about your driving style. I will be eventually going with the s60 in a couple years, but for now I can't afford it.
Old 03-28-2014, 08:37 PM
69TA's Avatar
solid pinion spacer, TA cover and a decent aftermarket tq arm is a good start
the thing that really kills these rearends in a stick car is the wheel hop.
Old 03-28-2014, 09:16 PM
VincesSS's Avatar
Originally Posted by 69TA
the thing that really kills these rearends in a stick car is a V8
Fixed that for ya.
Old 03-28-2014, 09:28 PM
ND2RACE's Avatar
So far the best advice in this thread is to avoid sticky tires, and wheel hop. I have broken and rebuilt a few 10 bolts, everything inside them is just too small to take a lot of abuse. Plus the bigger the ratio the smaller the pinion gear gets, all that ever happens when trying to go fast is that they break. So if you want it to last don't try to go fast.
Old 03-28-2014, 09:39 PM
01WS6/tamu's Avatar
Don't look through these replies with focusing on the small glimmers of hope and ignore the many that have gone through this telling you it's a waste. They suck, they suck and they suck some more for drag racing, but hey it's your money and it's your mistake to make.[/QUOTE]
Truth. Stick to roll races and never launch it hard. Start saving up you can do a 9" for under 2K if you are thrifty. Get the housing and axle shaft kit from here and then go hit a pick n pull for a 3rd member and posi unit.
Quick Reply: What can be done to a 10 bolt?
