Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Which bushing/mounts to inspect?
Old 03-21-2014, 10:03 AM
-Ross-'s Avatar
Default Which bushing/mounts to inspect?
Hey guys. I just got my 2005 CTS-V 2 weeks ago and have been reading up on the forums. Which bushings/mounts should I inspect first? Which ones are the first to fail and what do I need to look for?
At the present, I have a slight clunkish type of sound when I disengage the clutch between the 1-2 and 2-3 shift (probably have it during the other shifts, but at those speeds it's just not as noticeable).
I have also noticed the engine comes to a kind of rumbley/shakey stop when turning the car off. Not terrible, but it's there. I assume this is a motor mount issue.
Other than those 2 symptoms, the car seems pretty solid. No real vibration or anything while driving. The car is a 1-owner car with 42k miles.
Thanks in advance.
Old 03-21-2014, 10:18 AM
NIKDSC5's Avatar
You sir, need a new clutch. Get rid of that dual mass POS. Also, the diff bushing is first to go. But I would just start replacing all bushing. They are cheap enough and make a world of difference. Only problem is the PITA install process for some. Good luck!
Old 03-21-2014, 10:38 AM
BudRacing's Avatar
You definitely don't NEED a clutch at 42k, but the motor mounts are probably contributing the the shaking on shutdown. Check them for any fluid on them. When they fail, they crack and leak the fluid out. Sometimes it's hard to spot--be thorough. While the dual mass flywheel may make some noise, it and the clutch will likely last until ~100k.
You should replace the rear diff bushing and add the bracing block from creative steel. It's the first thing I did when I got mine and made a world of difference.
If your shifter is still stock, I would also look into upgrading that too. It will make your driving experience much better.
Old 03-21-2014, 11:19 AM
isis's Avatar
I was gonna type pretty much all of this. I'd also eyeball the transmission mount for sagging and add the revshift insert for that to your list.
Old 03-21-2014, 11:41 AM
DarkCharisma's Avatar
Engine mounts and differential front bushing at least. I replaced both of those as soon as I bought mine and it made a massive difference.
It seems the feedback on cradle bushings is stellar so far, control arm bushings are receiving positive reviews sans complaints of squeaking, but I have experience with neither of those so I can't speak authoritatively.
Ask me again in a couple months when I get around to installing my cradle/CA bushings.
ETA: I added the Revshift insert in my factory transmission mount, it fixed 1st to 2nd and helped locating reverse substantially.
Old 03-21-2014, 11:43 AM
NIKDSC5's Avatar
Well first off I think you would need to caps the Don't, not the Need for your point. But at any rate I have seen the dual mass chevy FW go bad in less than 20K miles before. The clutch itself yes, will last a long time, but the FW can go whenever it likes and cause a very similar situation to that of the OP's.
The shut down vib is def MM though OP.
Old 03-21-2014, 02:02 PM
stratass's Avatar
Great info guys!Nice clean car OP.
Old 03-21-2014, 02:14 PM
-Ross-'s Avatar
Thanks, everyone. I think I will start off with motor mounts, rear diff bushing/block and trans mount/bushing.
Quick Reply: Which bushing/mounts to inspect?
