new engine 1150 miles no oil pres
So i was driving and seen yhe light for gages come on and looked no oil p. so i pulled over and looked under hood. normal. but i heard a ticking from the rocker area. so i got it towed. got home oils in the heads and rockers look ok but a tad loose. what could it be?
Village Troll
It could be sudden loss of oil pressure. Get a mechanical gauge, place in port just above oil filter and verify it is not your sending unit. The ticking would be a bad sign of no oil pressure, however.
I'll put money on a the oil pump drive gear under the intake.
Did you put in a after market cam? Stock oil pump gear?
Buddy of mine, his cam ate his oil pump drive gear and had this exact problem.
Somebody needs to warn all the LT1 noobs out there somehow. I made the exact same mistake last year. Hotcam and HV oil pump. My rods waved goodbye about a week after I fixed the gear.
Haha, sorry. What I didn't mention is that I was really close to home and like an idiot I drove about a mile home after I lost the gear. I'm guessing that's what did me in. I've since learned my lesson and it sounds like you did the right thing and got towed right away. Can't hurt to pull the bearing caps just to be sure while your under there swapping the oil pump out though.
HV oilpump is usually a bigger problem than the aftermarket cam, some aftermarket cams have been sold with the wrong gear but the HV oilpump was just an extremely ignorant move that has been beaten to death here, people don't find that out though unless they are open to learning. Now if you made a choice that bad what else was done wrong? Lower compression, heavier pistons, LT4 springs with the heavier LT1 valves? I wish you luck but at the same time I would say prepare for the possibility of needing to find a used stock engine to replace this.
http://www.ebay.com/itm/Fed-Mogul-Premium-Engine-Rebuild-Kit-SBC-LT1-350-030-Bore-Stock-Rods-Mains-/331145444767?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d19ce7d9f&vxp=mtr
thats the kit we bought to rebuild the car with.
This was a very extremely low budget rebuild. We can't afford to drop 800$ pistons into our car and go on with our lives. Those pistons have given us no problems at all yet. The bottom end was professionally put back together by a decent shop around here. If he thought it would of been a problem he would of told us.
You do not need a HV oil pump, the most I go in my customers racing engine builds is a 10% higher volume oil pump. The oil pump that you installed is 25% higher volume than the stock oil pump and puts a lot of stress on the oil pump drive gear. That drive gear will break even with a stock oil pump let alone adding more stress to it.
To replace that pump, we would have to take off something in the suspension to get the pan off right? And then we got to tac weld the pick up tube back in place.
Your best bet is to put in a SV pump or you will be risking everything all over again. Some of the old "professionals" do not understand that the SV pump is actually better for most applications.
