Wiring up Eboost2 boost controller
i was wiring up my eboost2 boost controller, and was wondering if i needed to wire the yellow (tach signal) wire from the controller to the ground on a ign coil? is it mandatory, or can i run it without the tach signal? or what's the purpose for it anyways?
i would need this signal if i wanted it to spool faster in the lower rpms? my manual boost controller would spool slower at a setting of 11 psi, and would spool faster when i set it at 17psi.
