used nitrous kit need helping telling whats , what PICS INSIDE
Old 03-23-2014, 09:16 AM
wavebyby's Avatar
Default used nitrous kit need helping telling whats , what PICS INSIDE
Ok I bought a used maf gemini nitrous kit off here and the seller had it installed at a shop so hes not sure what each wire is for and neither do I , Im going to post up so pics to see if anyone can tell me what each wire is for . I have a bunch of Instructions but still kinda lost
RELAY ONE - 2 YELLOW WIRES , 1 GREEN WIRE AND 1 BLACK WIRE
RELAY TWO - ( MAYBE FOR BOTTLE HEATER ? ) 1 BLUE WIRE , 1 ORANGE WIRE , 1 RED WIRE AND 1 BLUE WIRE .
RPM ACTIVATED WINDOW SWITCH - I KNOW WHERE THE WIRES GO BUT THE INSTRUCTIONS SAY FOR 8 CYLINDER LEAVE RED AND BLUE WIRE LOOPS THESE ARE CUT WHICH IS FOR THE 4 CYLINDER IS THAT RIGHT ? ?
FUEL SAFTY SWITCH - ONE PORT SAYS ( C ) THE OTHER SAYS ( NO ) WHICH ON IS GROUND/POWER
MAIN HARNESS EVERYTHING IS ALL TAPPED AND IN WIRE LOOM THE ONLY THING COMING OUT OF THE HARNESS IS , 1 RED POWER WIRE , 1 GREEN WIRE ?, 1 YELL0W WIRE ?, 1 WHITE TPS WIRE , AND 1 BLACK WIRE GROUND ?
ALSO THE NOIDS ARE WIRED IN THE HARNESS AND NOT SURE IF THE WIRE COMING OFF EACH IS A GROUND OR A POWER WIRE ????
NEED HELP ON THIS !!! ..... SECOND GUESSING BUYING A USED KIT
ILL POST PICS FROM MY PHONE IN A MIN
Old 03-23-2014, 09:21 AM
wavebyby's Avatar
heres the wires
Attached Thumbnails used nitrous kit need helping telling whats , what PICS INSIDE-image.jpg
Old 03-23-2014, 09:22 AM
wavebyby's Avatar
relay .....
Old 03-23-2014, 09:25 AM
wavebyby's Avatar
wires....
Old 03-23-2014, 09:26 AM
wavebyby's Avatar
can only add on at a time very annoying
Old 03-23-2014, 10:45 AM
slammin86's Avatar
First thing I would do is cut apart that harness and separate the wires to make your own harness.
Old 03-23-2014, 12:01 PM
wavebyby's Avatar
Thanks i ended up doing just that . I wanted to keep it altogether because all the relays , tps , window switch and everything was all wired up as one but i didnt know what was what because all the colors were wrong so just took it apart to make my own
Old 03-23-2014, 02:11 PM
slammin86's Avatar
Yes in the long run that will be the easiest.
Old 03-23-2014, 05:52 PM
wavebyby's Avatar
Ok i got it all rewired up
Old 03-23-2014, 08:03 PM
slammin86's Avatar
Pics?
Old 03-23-2014, 08:43 PM
wavebyby's Avatar
here u go
Old 03-23-2014, 08:45 PM
wavebyby's Avatar
heres another
Quick Reply: used nitrous kit need helping telling whats , what PICS INSIDE
