Which nozzle is the best.
I did some searching but its hard to find all the things youre looking for.
I had a 78mm plate and recently went upto a fast102. that being said i just dont have the funds there to buy a 102mm plate. So i am going to throw on a nozzle on it. im staying around the 150-200 shot mark. I also wondered do you usually just bolt the nozzle into your bellow? i use to have a nozzle way back in the day and put it in the bellow, it also seemed like the nozzle would move directions and sometimes and be spraying directly into the bellow instead of through the throttle body. is there anyway to stop that? thanks.
or should i just stop being a penny pincher and just buy the plate.
i have the ny trex hi flow wet nozzle they claim its good up to a 300 shot and ive been spraying a 200 shot with it.. the nozzle doesnt move around that much and if so you could route the lines to help hold it steady. i got something like this in my bellows
http://www.ebay.com/itm/DEI-150055-Ny-Trex-Nozzle-Adapter-Nitrous-1-8-/260877101458?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cbd7ca992&vxp=mtr
NX kit here with the shark nozzle mounted into the bellow. I basically used a few washers to hold the nozzle in place to spray directly into the TB, and it works great!
thanks for some of the input guys.. still might just go nozzle for the time being, last month i bought a 9",wheels,susp, and other stuff. i have only been married for 4 months now and i feel the divorce getting closer everytime i click that add to cart button lol.
Ls1tech & Truck Sponsor
Dei 150055 NY Trex Nozzle Adapter Nitrous 1 8" | eBay
This is what you need. We sell the nozzle systems, the nozzles, and the adapter that this guy linked. It screws into this two piece nut that is threaded for 1/8 to keep it from moving around.
-Garrett
i have the shark nozzle too. needed to put a washer to keep it from bending with the weight of the lines on it. got to route the lines to where it sprays to the tb. the fuel line should be closer to the tb when parallel to the ground.
