Stock '00 LS1 cam specs
Old 05-14-2004, 10:55 AM
Andy1's Avatar
Default Stock '00 LS1 cam specs
Can someone kindly post the stock '00 LS1 cam specs or where I can find them?
Thanks,
Andy
Old 05-14-2004, 11:21 AM
99 Pewter TA's Avatar
198/208 .500' lift. Found this at <www.ls1howto.com> under cam install.
Old 05-14-2004, 05:02 PM
jrp
SN95 Director
jrp's Avatar
info link in sig
Old 05-14-2004, 05:29 PM
Cal
Cal's Avatar
That's the Corvette LS1 cam . . . the Fbody LS1 cam is smaller: 0.478 lift. As stated on JPR's page, this is the 6.0L truck cam. An fbody deserves a much bigger cam than this.
Old 05-14-2004, 06:44 PM
52172's Avatar
the f body has the same cam as the corvette i believe it is the 01 and newer f bodies that have the truck cam.
Old 05-14-2004, 11:06 PM
Cal
Cal's Avatar
I just looked up those specs; it was the 01 and 02 fbodies that have the truck cam, but fbody LS1's have always had slightly different cams that Corvettes:
stock LS1 cam '98-00:
202/210 intake/exhaust degrees duration
.496/.496 inches lift
116 LSA
stock LS1 cam '01-02:
198/197 intake/exhaust degrees duration
.478/.478 inches lift
115 LSA
Old 05-15-2004, 10:39 PM
1BADFNZ's Avatar
116 LSA
115 LSA
Holy Crap that sucks
I really gotta replace that
Old 05-17-2004, 03:40 AM
Unaffliated Racing's Avatar
This info is incorrect
116 LSA
115 LSA
here is the correct info as spec'd by a $250,000 machine at Comp
stock 98 trans am cam
duration@.050 198.86 intake 209.25 exhaust
lift .498 intake .497 exhaust
LSA 119.45
stock 02 trans am cam
duration@.050 196.37 intake 208.72 exhaust
lift .464 intake .479 exhaust
LSA 115.92
Quick Reply: Stock '00 LS1 cam specs
