Dominator fuel pressure question
What are you guys doing to communicate the fuel pressure to the ecu? I see the sensor you can buy for $115 and was curious what you guys are using. Is there a cheaper option that doesn't suck? Does this use up a output function or is it built into the harness
8 Second Truck Club
I've used both a transducer from Holley and one from Autometer and they both worked fine. Also I currently have the signal split between the Dominator box and the Autometer FP gauge.
I have an extra Autometer transducer I'll sell to you so that you can save some money. PM me if you are interested.
I was told by another member here that this ebay sender works with Holley's EFI.
http://www.ebay.com/itm/Pressure-transducer-sender-100-psi-stainless-steel-oil-fuel-air-water-/261260635816?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3cd458eea8
I bought 2 of them, but I have not tested them yet. My dominator setup will be installed hopefully in 2-3 weeks.
Pressure Transducer or Sender 100 PSI Stainless Steel for Oil Fuel Air Water | eBay
now if I can find a fuel pressure guage without a sender ill be in business
