What Nitrous kit for Cam Only ls1?
I swapped a ls1 with a cam in my 91 c1500 and i always wanted to go nitrous so i think its time i make a move...I did some research and they say a wet 150 is safe? Is that true? And should i get the 78mm plate? Nitrous outlet or Nitrous express? And what else would i need to get/do? Thanks
Truck has a rebuilt ls1 with a 227/235 cam, longtubes and cold air intake, 28lb injectors and 255 fuel pump.. 5 speed with 4.10s...i will only be using nitrous on the weekends when i go to the drags...any opinions welcome and thanks for looking!
150 is safe as long as you have your ducks in a row. You want to have the correct A/F ratio, be on the right plug, and have the right amount of timing in the motor. Would you want a braided hose system or one with hard lines?Here are a couple links for you to check out.
78mm Braided Hose kit:http://www.nitrousoutlet.com/nitrous...te-system.html
78mm Hard Line System: http://www.nitrousoutlet.com/nitrous...te-system.html (I know this says for F-body but if you're running an Ls1/6 intake it will fit fine.)
Accessory Packages: http://www.nitrousoutlet.com/nitrous...-packages.html
I would also recommend you a window switch: http://www.nitrousoutlet.com/electro...ow-switch.html
And a way to pull timing: http://www.nitrousoutlet.com/electro...ontroller.html
This is the spark plug you will want to run: http://www.nitrousoutlet.com/electro...ps-colder.html
All of these components make a safe and reliable system that will make all of the power you want. If you have any questions about any of these items please feel free to ask!
Thanks for the info Brandon! I was looking at the plate kit for the f body's and i like how its setup on the intake...i will give you guys a call within a month or so. Thanks!
Alright guys its been a while, but Im finally putting in my t56 next week and since i am going nitrous i was wondering what would be best to activate the nitrous... I want to push a button instead of having the switch on the pedal... Does anyone sell shift ***** with the button?
