Bosch 044 pump as an intake pump???
Old 03-27-2014, 10:00 AM
TableLeg's Avatar
Default Bosch 044 pump as an intake pump???
Does anybody know if an External Bosch 044 fuel pump can be converted so as to fit as an Internal pump on a tank currently without an intank pump?
Is there a cradle/bracket of some type that can bought to attach the pump to and then lowered into a suitably modified tank?
Thanks for any info.
Old 03-27-2014, 06:54 PM
Ollie8974's Avatar
An external pump can not be modified for internal use.
Yes, Tanks inc bracket with pump.
http://www.tanksinc.com/index.cfm/pa...=cat/cat61.htm
Old 03-29-2014, 02:42 AM
TableLeg's Avatar
Thanks Ollie8974
Old 03-29-2014, 04:28 AM
stevieturbo's Avatar
The 044 can be used in tank or external ( as indeed can many external pumps ). Do not listen to anyone who says otherwise.
But make sure the tank design is suitable for an in-tank pump with a built in collector/swirl around the pump to ensure it never runs dry due to fuel slosh.
Quick Reply: Bosch 044 pump as an intake pump???
