s475 /s476 how fast
I don't think 60 ft is going to be relevant.
There are several people on this forum that have been in the 8s on either turbo. There are a couple here in the low-mid 8s on the S476R.
76mm turbos have been in the 7's on 3000+ lb V8s. A billet Borg Warner S476R with a 96mm wheel and a race cover should be capable of 1200 whp.
my daily type driver on a standard 475 t4 and a 302 with low boost went 1.58@60, 6.20@117.5, and 9.55@148. 3400 lbs, standard m/t 275, 3.25 gears... and mine is nothing special at all compared to what some guys are doing.
a 6.29 on a 1.5 60ft impressive for that 60. What stall speed are most these fast guys running any info? trying to run a class this year thats limited to a 76mm cast wheel turbo just making sure that im capable of mid 5s on the s475 or 76. keep the times coming
Stall speeds in the low 3000 range are common. I don't think I've seen lower than 2800 or higher than 3800. I went with 3200 stall triple disk Circle D. I'm also going from a billet to cast wheel for x235, although I don't think I'll make it out this year since I don't have an 8.50 cert cage yet.
The S475 is capable of 5.60s without pushing it to the absolute limits. There are guys running mid 5.30s around here on a cast 76.
jason Rigney has been 5.16@138 and change with the S476R.... Matt Lawrence also went 5.16 with it.
Josh Castle went 5.60's with an S475 iirc.... might've been 5.80's..... car went 8.8X@153 with that 699 special.
