Injector swap
Injector swap
I am looking to increase injector size for my lq4 swap project. I am considering a couple of bosch injectors that I can get for a good price: 0280156201 (36#) or 0 280 155 831 (30#).
Harness is not built yet so connector type can be adapted. I am running aftermarket intake/fuel rails so I don't believe height will be an issue either. My question is can I pretty much swap in any high impediance EV1/EV6 multiport bosch injector with sufficient flow? Will a tuner run in to difficulty setting up pcm for either of these?
IFR is pretty straightforward, rating @ x PSI, then what are you running them at pressure wise compared to their rating. *look at my fuel & injector sticky, if you don't understand PM me and we can hash it out.
then offset table, short pulsewidth, minimum pulsewidth, a few others
