CNC'd LT4 flow numbers..
Old 05-14-2004, 01:47 PM
8 Sec Tuner
Mike TexaSS's Avatar
Default CNC'd LT4 flow numbers..
This isnt LS1 related but these are a really nice set of heads that MTI did about 4 years ago that i just had new valves put in.
The heads were completed yesterday. I had them flowed at lunch today by a friend.
4.030 bore on a Superflow 1020 bench.
The heads have Manley 2.02 intake valves and 1.60 exhaust valves.
All cylinders were within 5-6 cfm of each other..
----Intake Exhaust
.200--143--110
.300--207--147
.350--232--163
.400--253--178
.450--270--187
.500--282--194
.550--285--201
.600--286--206
.650--288--210
From what ive seen i have a monster set of heads. Which is why my car has always been so strong with a measly HOTCAM.
4.030 Bore
4.00 Stroke
408 cid
With the head flow numbers and my engine size anyone wanna recomend a Cam?
Old 05-14-2004, 02:16 PM
JS
JS's Avatar
Here's the set of TEA S3 LT1's we just got for a customers 383 we're building.
Same bore flowed as u.
.100.....67.9/58.9
.200.....135.7/114.8
.300.....192.2/160.7
.400.....238.7/203.9
.500.....275.0/227.2
.550.....280.4/234.4
.600.....283.1/240.9
Old 05-14-2004, 02:20 PM
8 Sec Tuner
Wow do you have pics of the exhaust ports. What size valves?
How are they getting 30 more cfms than mine?
Old 05-14-2004, 02:23 PM
JS
JS's Avatar
Call TEA
Old 05-14-2004, 02:26 PM
8 Sec Tuner
Gotcha
Old 05-14-2004, 09:11 PM
TT-TECH Veteran
Inspector12's Avatar
Mike,
They use a pipe on the exhaust ports hwen testing they will tell you the same thing. They said it simulates headers ETC...
Jeff
Old 05-14-2004, 10:52 PM
destroyerSS's Avatar
I was told by a few reputable people here that there high exhaust #'s are from their flow bench. I'm not bashing at all and in Know way am i saying there heads are bad, just that there flow #'s through the exhaust are rated high and if they were flowed on a different bench they would be lower
Old 05-14-2004, 10:57 PM
WS6 #3392's Avatar
Does any one know the stock flow numbers of LT1 and LT4 heads?
Old 05-14-2004, 10:58 PM
LSX Mechanic
Damian's Avatar
The reason the exhaust numbers are high at TEA is b/c they are flowed with a pipe.
Old 05-17-2004, 08:22 AM
8 Sec Tuner
Mine were flowed with a open exhaust port..
