On3 turbo, 5.3 track results
Setup is
Stock 5.3
Stock 862 heads
216/221 camshaft
Huron speed turbo kit
On3 76mm
Th400
E85
Full weight car with only a pa racing k member.
This run was made on 19psi.
6.40@108
Should be good for a high 9 in the 1/4 I hope. Car is a blast and fun to drive! My best 60ft is a 1.38. If I can get the 60ft back to that, should go a 6.30.
On3 76 6.40@108 on Vimeo
Stock 5.3
Stock 862 heads
216/221 camshaft
On3 76mm
Th400
E85
6.40@108
Just running the 3" downpipe that came with the Huron kit. It dumps behind the k member on passenger side. And yes it's the 65mm. I'm shifting at 57-5800, turbo is done past that.
Setup is Stock 5.3 Stock 862 heads 216/221 camshaft Huron speed turbo kit On3 76mm Th400 E85 Full weight car with only a pa racing k member. This run was made on 19psi. 6.40@108 Should be good for a high 9 in the 1/4 I hope. Car is a blast and fun to drive! My best 60ft is a 1.38. If I can get the 60ft back to that, should go a 6.30. Video Link: http://vimeo.com/90383138
