Catch can
http://www.mightymousesolutions.com hit up david, he has plenty of options on his and can build to suit your setup.
The Founders pieces are high quality and I am liking them so far. I'm running the relocation brackets, adjustable torque arm, on car adjustable rod/rod panhard bar and the on car adjustable poly/rod lower control arms. If you are thinking of upgrading some components I wouldn't hesitate to recommend them. I also have a spare UMI torque arm relocation crossmember for a 4L60E if you haven't taken the torque arm off your trans yet and are running an auto.
Im running an M6. You know if their torque arm will mount off the tail housing of the trans with a different crossmember? Just dont want to get one that only mounts one way. And this is now way off topic. And I will check them out. I have seen his parts before. Will do further research. LOL
Last edited by 2000Hawk#317; 04-02-2014 at 10:46 PM. Reason: For got to comment on other post.
