Tuning Q's w/ M-9593-BB302 (Bosch III 30lb) injector offset tables
Old 03-30-2014, 03:57 PM
mpe331lx's Avatar
Default Tuning Q's w/ M-9593-BB302 (Bosch III 30lb) injector offset tables
Does anyone have the correct inputs for these injectors in an LT1 using TunerCAT? (Specifically in the "Injector Offset vs Battery Voltage" and " low pulse width injector offset adder vs bpw" tables)
I recently switchd from a set of 03/04 Cobra 39lb injectors in my H/C LT1 to a set of bosch III 30 Lb injectors (AKA skinny ford 30LB M-9593-BB302 , FIC 32LB).
I have searched, and searched for the correct injector offsets to run these in an LT1 but only find the tables from ford.
It seems most leave the tables alone when running the older fat top #30's, but the slim ev6 style injectors dump more fuel at lower pulsewidths and require more than just setting the injector flow rate in the constants table.
Quick Reply: Tuning Q's w/ M-9593-BB302 (Bosch III 30lb) injector offset tables
