cruise control not working
After changing clutch master and slave cylinders on my 2002 WS6 my cruise control is not working.
I read a lot in the forums here that there is switch right above the clutch pedal that needs adjustment for the CC to work again.
Can someone please send me a pic of this switch?? and explain how should I rotate it ?
Thanks a lot.
Thanks a lot.
Yes the the white plug at the top of the pedal assembly bracket where the master connects to is the depression switch which disengages cruise control
It pops into the white bracket which you then can rotate clock wise to push the sensor in further to contact the arm that depresses when you push in the clutch pedal.
There is also another bracket above the brake light switch which is the same cruise depression switch
