What clutch to hold 1000+HP?
Old 03-31-2014, 02:58 PM
ABeasst's Avatar
Default What clutch to hold 1000+HP?
I have a mcleod twin disk and it decided to start slipping at 974RWHP. My car has plenty left in it so I'm trying to see what clutches everybody is running now for a high HP street/strip turbo car.
Thanks
Old 03-31-2014, 03:03 PM
oscs's Avatar
Mcleod RXT?
Old 03-31-2014, 03:52 PM
87silverbullet's Avatar
Textrailia? ACT? SPEC super twin?
Which Mcleod did you have as there are 2 that I see the RST and RXT?
Old 03-31-2014, 03:59 PM
VIPERSLYR's Avatar
I'm running a monster clutch and I really like it great pedal feel and great guys to deal with
Old 03-31-2014, 04:27 PM
Chicago TDP's Avatar
I think they are rated at 1000 crank HP so you might be beyond the clutch's limit.
Not sure what else it out there that can take it....
your poor trans....lol
Old 03-31-2014, 09:16 PM
blue99fbody's Avatar
monster lt1r twin or their new triple version of it. thats what i will be using for mine this year at 1000+rwhp. cant beat monsters customer service
Old 03-31-2014, 09:17 PM
rkreigh's Avatar
Mantic makes a nice product
and I like the RAM dual disk
lots of folks chose the McLeod
many of the dual disk setups are rated for 1k hp and are still streetable
I didn't like the "grabby" nature of the textralia single disk I had and went with an automatic
I think if I had converted over to a decent dual disk I might have changed my mind. but I do like the way the ttix and auto work together
Old 03-31-2014, 10:29 PM
runsfromdacops's Avatar
i have a low mile rxt twin with a steel flywheel (3k miles) im thinking about selling if your in the market.
my car made 900whp and showed no signs of slipping
-alex
Old 03-31-2014, 10:31 PM
js2fst's Avatar
I would try a ls7 before I would try a spec twin
Old 03-31-2014, 11:57 PM
Detoxx03's Avatar
Mantic 9000 or a RPS Triple.
Old 04-01-2014, 02:26 AM
Brian Hoss's Avatar
Centerforce DYAD.
Old 04-01-2014, 12:13 PM
gnx7's Avatar
Did you do a proper break in on the McLeod clutch? Or immediately go beat on it?
McLeod offers a triple disc setup they don't advertise. Maybe look into that....
Old 04-01-2014, 12:27 PM
oscs's Avatar
This makes no sense
Old 04-01-2014, 12:37 PM
NnOoSsSs's Avatar
I wonder if hes serious
Old 04-01-2014, 12:45 PM
V-seriesTech's Avatar
Originally Posted by oscs
This makes no sense
Does it?
spec clutch, my car. ^^^
Another car later,...about 4 clutch setups later... I now have this.
I ended up with a Tilton 7.25″ 4-Plate Carbon OT-II Racing Clutch. It's pretty sick. Your supposed to be able to slip it to kingdom come...so,..we'll see. It weighs about 14.7lbs with flywheel attached.
Based off what I have seen/learn and installed on manual cars(which is my bread and butter)I would recommend a MCLEOD for just about any setup. They pretty much have the clutch you want, for any car. Honestly they're customer service is awesome...they will truly help you out with any and all questions.... very great company. Unfortunately my $6,000++ Tilton, doesn't come with nearly the same sort of customer care. When I call them with setup/questions.... they refer me to one of their vendors......
So, Mcleod, I would recommend. I like my textralia exo skel but the twin disc didn't hold my power. Sub 1000 hp no problem though.
Call Mcleod...talk to I think "Paul"..he's the owner.
Old 04-01-2014, 01:04 PM
^^^^That's not the point. The point is that an LS7 would slip its *** off before it could even do that to itself at 1000hp.
I will say that alot of companies have come a long way in making good clutches because back in the day, all you had was SPEC, McLeod and centerforce for LS stuff.
Old 04-01-2014, 03:46 PM
js2fst's Avatar
And the spec doesn't slip. And fail??? The pressure plate was my common failure. mccleod I had luck with in vette!
Old 04-01-2014, 04:32 PM
oscs's Avatar
Originally Posted by V-seriesTech
Does it?
that sucks but What does your spec clutch failure have to do with an LS7 clutch holding 1000RWHP?
So what? an LS7 clutch is not designed to handle anything close to 1000RWHP end of story
Old 04-01-2014, 04:36 PM
oscs's Avatar
OP you still haven't told us EXACTLY what clutch your running.
Old 04-01-2014, 04:47 PM
When you have a pressure plate failure twice, in 2 weeks, 2 separate cars, to separate installers, 2 separate conditions, 1 common denominator=spec. Actually, 2 common denominators, both had SPEC, both cars were total losses, due to SPEC clutch products.
I would run a stock LS6 clutch and HATE life before I would run a **** PILE SPEC PRODUCT is what I mean since logic doesn't grace everyone.
RAM has been in the game as long as SPEC has when it comes LS cars. I have also had them. RAM is good to for most setups. Mcleod is the best I have seen when it comes to working/customer care.
Chances are, I have changed more clutch setups then most people. I have a garage full of take out spec clutchs and textrailia exoskels. I think I have even a ram laying around.
trust me, I use and test clutch assemblies more then you'd ever want to.
moral of "my" rant, is to advise people of SPEC products and to steer them away from them.
You like your legs, don't you? Ever have a pressure plate explode at 5,000 rpm?
Quick Reply: What clutch to hold 1000+HP?
