Fender gap question (pics)
Location: Land of the Mormon's although I'm not one of them
Door hinge bushing wear is a possibility. Take a look at the bushings or see if the upper door hinge shifted in any way. Also, there is a bolt that is up at the top of the fender in that area, that may have worked loose.
Looked at the hinges/bushings, I found it hard to see a difference versus the drivers side but I'm starting to think the door is sagging maybe? The gap between the passenger side rear quarter panel/passenger door is slightly larger than on the drivers side. Not really sure but just throwing it out there
Also thanks for your input
