Idling issue after le2/cc306
Old 04-03-2014, 08:44 AM
KyleW707's Avatar
Default Idling issue after le2/cc306
Car is a 97 z28. When I originally bought it, as far as the engine goes, it had stock heads, lt4 hotcam, and shorty headers, ran fine. Then did a full rebuild and added le1 heads, cc503, long tubes, tune, again, it ran fine. Then did le2 heads, cc306 and now it runs rough at idle. I can hold it at 1000-1200 rpm and it smooths out, and when I rev it, it's smooth as can be, doesn't hesitate or anything. Fpr, injectors, and acdelco (denso) o2 sensors were on the previous build and were bought new (build had about 200 miles on it before I tore it down again), but I checked them anyways and they're fine. New acdelco plugs gapped at .45 with the le2 and c306. I can think of only two other things that may be causing this. One, would be the plug wires, from when I bought it until now, it had Taylor 8.5mm wires, without giving it much thought, I replaced them with new acdelco 7.5mm. Problem??? Two, it's still not tuned for the le2's and cc306, it's still on my le1 and cc503 tune, but I think that's less likely of the two. Any other ideas? Pulls no codes, and never has besides an icm code, that has been there since I've bought it, but I haven't had any problems with it.
Old 04-03-2014, 09:16 AM
big hammer's Avatar
does it sound like this?
Old 04-03-2014, 09:57 AM
draggin97s10's Avatar
Needs to be tuned
Old 04-03-2014, 10:44 AM
KyleW707's Avatar
This is it, you can hear it almost die after the 2nd rev. Idling the whole car shakes. I understand the cc306 is choppy, but I also know the difference between choppy and rough. It's more like a big or multiple misfire, but it's not pulling any misfire codes, not even po300 (random/multiple cylinder misfire)
http://youtu.be/FSNaeg6hDi4
Old 04-03-2014, 10:49 AM
pillarpod's Avatar
I would start with ^^THIS^^ problem first.
Old 04-03-2014, 10:55 AM
guppymech's Avatar
Probably the lack of a tune for the 306, idle sounds too low for that cam.
Old 04-03-2014, 11:20 AM
KyleW707's Avatar
Guess I'll start with the tune, won't be back in town until next weekend though! I'll have to get a obd2 mail order until I can get it to my tuner. Still looking for a 94-95 pcm so my guy can tune it though. If y'all hear of one let me know
Old 04-03-2014, 11:47 AM
guppymech's Avatar
Madtuner sells pcms, at least until Sept 1 when he ditches the LT1.
Old 04-03-2014, 02:48 PM
KyleW707's Avatar
Old tune was through pcmforless, probably will just have them reflash it and go from there
Old 04-03-2014, 03:03 PM
BALLSS's Avatar
if you have a scan tool, check IAC counts at idle...are they pegged at 160?
email your tuner and ask if your tune needs to be adjusted for this new cam (likely)
Old 04-03-2014, 03:07 PM
KyleW707's Avatar
I do have one, but currently out of town for work until next weekend
Old 04-03-2014, 03:08 PM
KyleW707's Avatar
Good thing about my tuner, he used to have a lt1 with the 306 so he shouldn't have any problem tuning mine!
Old 04-04-2014, 11:59 AM
Spartan7's Avatar
There's your problem right there. They suck, get a decent tune from someone else. I would also do what was said before, and check your IAC counts.
I ran a 228/236 just fine for a few miles on a tune for a 222/230 and it did not have the problem you had, just throwing that out there.
Old 04-04-2014, 12:07 PM
Puck's Avatar
With a cam like the 306 with its lazy lobes and high overlap you most definitely need a tune. Preferably a proper dyno tune, not a mail order.
Old 04-04-2014, 12:14 PM
KyleW707's Avatar
I do plan on getting a dyno tune, but have to get an obd1 pcm first. But like I said, outta town until next weekend. I'll get the tune done and report back
Old 04-07-2014, 05:32 PM
96TransAmboosted's Avatar
My 306 car needed a tune before it would idle at all.
Quick Reply: Idling issue after le2/cc306
