Wtb 2001 abs module
Old 04-03-2014, 08:37 PM
Randolph Ziskey's Avatar
Default Wtb 2001 abs module
Anyone parting out a 2001 m6 ws6 with 3 channel abs. I would like to buy from you the abs module or if anyone has one off a 2001 laying around please let me know. Shipped to texas please.
Thanks!!!
Old 04-03-2014, 11:12 PM
Old 04-03-2014, 11:26 PM
transamfreak01's Avatar
I have a 4 channel abs unit. If your interested shoot me a pm
Old 04-03-2014, 11:29 PM
Let me make sure the 4 channel will work on a 3 channel. Mines a 3 channel.
Old 04-04-2014, 07:43 AM
01ssreda4's Avatar
No, it will not work. 3 channel only has one line running to the rear, 4 channel has two.
Old 04-04-2014, 07:00 PM
Anyone with a 3 channel from 2001 m6?
Old 04-04-2014, 07:25 PM
Undertow74's Avatar
Yours doesn't have traction control?
Old 04-04-2014, 07:29 PM
No traction control.
Old 04-04-2014, 08:41 PM
Undertow74's Avatar
Damn. Because I have a 4 channel I'm getting rid of.
Old 04-05-2014, 04:36 PM
01ssreda4's Avatar
Check ebay.
Old 04-05-2014, 06:37 PM
Dumb question but does it matter if the car was automatic or m6? Will either work on my 2001 m6? I now know it has to be 3 channel non tcs.
Old 04-06-2014, 11:37 AM
01ssreda4's Avatar
No, auto vs manual makes no difference.
Old 04-07-2014, 08:44 PM
Well found this off of place that rebuilds abs modules just in case anyone else is having abs inop/low trac trouble...
"Is your vehicle having ABS problems? We can offer you a solution!!!
Here are the most common symptoms that let you know that the ABS/EBCM has failed or is failing...
•ABS PUMP ALWAYS RUNNING
•NO COMMUNICATION
•RELAY CODES
•ABS LIGHT ON OR COMING ON INTERMITTENTLY
•WHEEL SPEED SENSOR CODES
•CODE... C0265 (ABS MODULE FAILURE)
•CODE... C0267 (ABS PUMP RUNNING CONSTANTLY)
•CODE... C0268 (SHORTED OR OPEN ABS PUMP CIRCUIT)"
Quick Reply: Wtb 2001 abs module
