Synapse Synchronic WG Question
Anyone out there clock one of these? I've never disassembled it but realized after getting everything together (bypasses to DP) that the top two vacuum nipples are pointing towards the passenger radiator tank and awful close for comfort even without a bend radius of hardly any kind. I see the top comes apart from the lower section with allen heads, anyone know if you can rotate that X amount of degrees and lock it down? These wastegates aren't your typical diaphragm setup that can be easily turned, and I cannot turn the base because of it bypassing into the downpipe.
Anyone?
Anyone?
The video was a good source of info I thought - although it doesn't directly answer your question I thought the internal shots gave a good hint that you could clock it like you describe.
Also after seeing this video I'm much more interested in these, and I understand why so many people are afraid of them
Jay - Thanks man, you're right, looks like a half dozen m4's holding it together. I'll take it off the car and disassemble it.
