Cutting springs
Cutting springs
I know this is not really the right way to do it but wondered if those of you that have are cutting from the big or small end on the front springs? Top or bottom?
Eh, I think most who've cut springs on this car are no where near the same league as the import spring cutters. Typically very conservative. Personally, I'm happy with the ride of the OEM setup and want to decrease the wheel gap only by a hair. I plan on cutting both the front a rear springs. About a 1/2 coil off the top of the fronts, and likely about 3/4 from the rear with a MM type spacer installed.
Fweasel I plan on doing exactly what you just said. I've read that people who do cut there springs are pleased with the results. I don't see a problem with cutting the springs if all you're doing is like cutting one coil, not trying to slam it by cutting the springs like the import folks
I was not sure on the front springs obviously the rear you can only cut the big end. I took about 3/4 off the front and close to 1 off the rear with mm spacers car sits with just a touch of rake and still rides good. I did not want it as low as h&r was the reason for cutting and not buying and so far I am happy with the results. Just needs an alignment.
Yeah I used the mm spacers and trimmed the bump stops. The ride is actually better than I thought it would be, it does not bounce much if at all. I know the roads in Michigan suck too.
Everyone always cringes at the mention of cutting springs, but the main point to consider is if the OEM springs are linear or progressive. The V springs are linear, making them acceptable to cut. The H&R springs are progressive so that they maintain similar to stock feel while being much lower than stock.
