ABS, and TCS reluctor rings. HELP
Old 04-04-2014, 09:06 PM
96LT1Z's Avatar
Default ABS, and TCS reluctor rings. HELP
Alright I have 1996 Z28 Camaro. It has ABS and Traction Control. I pulled the axles out and they are mix matched and they are not stock. I think one of them is causing a vibration that ruined my wheel bearing on the pass side. Heres the deal its a 4 channel and I NEED THE RELUCTOR RINGS. Because they are two different sizes and making my abs and traction control freak out. I cant find them anywhere. I can find the center reluctor on the carrier. But I need the two small ones that go on the ends of the axles!! HELP I need a part # or something.
Old 04-04-2014, 09:25 PM
nascarnate326's Avatar
Heat the rings up and take them off. I had to and had no issues after.
Old 04-04-2014, 09:27 PM
96LT1Z's Avatar
Getting them off im not worried about. I have one Lt1 ring and one ls1 ring. I need another lt1
Old 04-05-2014, 05:40 AM
FirstYrLS1Z's Avatar
GM never had a part number for the axle reluctor rings as they come as part of the axle on a 4 channel car.
Old 04-05-2014, 04:50 PM
96LT1Z's Avatar
could I just put the 3 channel axles in and just have my tcs and abs not work?
Old 04-11-2014, 02:53 AM
WertyLimit's Avatar
Check this thread: https://ls1tech.com/forums/gears-axl...-drawings.html Its from 2002 firebird LS1 stock 10 bolt rear. http://www.reluctorrings.com This company can make you LT1 rings if you have dimensions.
Old 04-11-2014, 07:50 AM
01ssreda4's Avatar
Gonna have to buy a whole axle on the used market to get the wheel. Yes you can swap in non-wheeled axles and there will be no issues except abs and TCS won't work.
Quick Reply: ABS, and TCS reluctor rings. HELP
