Double Pass Heat Exchanger
...... with fans.
Thinking about this for my Whipple. Anybody used one with their PD blower? How do you like it?
I bet it will work very well but generally speaking a vertical flow single pass should cool a little better as the majority of cooling is done in the first 6" or so due to the extreme temperature differential vs ambient. As long as it can flow enough you should be just fine and pretty happy I think.
Thanks for the input. At the moment, I'm using the single pass that comes with the Whipple kit. It's fine at 10 psi. That said, plans are to go to 13 psi (more blower rpm more heat) so I'm thinking about different things to help cool things down.
