Looking for a head that flows around 320cc's BUT doesn't cost $3K!
Old 05-14-2004, 11:55 PM
The Guy in MY 99TA's Avatar
Default Looking for a head that flows around 320cc's BUT doesn't cost $3K!
I'm going to start my buildup here soon and I was looking for a good head(probably a ls6 casting or a 6.0 since I will be using a 6.0 block).
Anyone got any leads to where I can find these?
Josh S.
Old 05-15-2004, 09:55 AM
dand35th's Avatar
TEA
Old 05-15-2004, 10:07 AM
Nasty N8's Avatar
I can do a set that flow that much for way less than $3000.
Thanks Nate
Old 05-15-2004, 10:58 AM
Ben R's Avatar
Remember, you get what you pay for.
Old 05-15-2004, 12:31 PM
Chuck@'s Avatar
Thumbs up
Very much true.
I try almost daily to figure out ways to get our cylinder head packages to cost less than what they do... but there is simply no way around it, quality costs money. Our heads flow among the best in the market, if not the best, but our pricing is definitely not cheap comparatively! The only way I could get the prices down would be to use cheaper valves, cheaper springs, and cheaper retainers/locks. But that really isn't how I want to run my business. I'd rather all our products be of the highest quality possible.
Having said that though, 320 cfm is easy, and I think we could probably do it for under 3k...
Chuck
Old 05-15-2004, 01:48 PM
UnbelievabLS1's Avatar
My TEA Stg 2.5 5.3's flow that much!
Old 05-15-2004, 03:54 PM
Under criminal investigation for fraud
Chris@AP-Engineering's Avatar
Our 6.0 liter race heads are just over $2000 and flow over what you are looking for. If you have any questions just give us a call or email us.
Thanks
Old 05-15-2004, 06:50 PM
masterdill's Avatar
I'll sell you a head that flows 320cc's for $100
Old 05-15-2004, 07:51 PM
BigTex's Avatar
My TEA 6 liter stage 2.5s just came in: 329 / 279 @ .600 lift.
Old 05-15-2004, 11:47 PM
10secondZ's Avatar
My thoughts exactly lol..
Old 05-16-2004, 08:02 AM
Ed Curtis's Avatar
Exclamation
Originally Posted by The Guy in MY 99TA
I'm going to start my buildup here soon and I was looking for a good head (probably a ls6 casting or a 6.0 since I will be using a 6.0 block).
Josh S.
Questions:
Why 320 cfm as a benchmark?
Where did this "magic" number come from?
At what lift are you looking for this "magic" number?
At what port volume are you looking for this "magic" number?
Who's testing methods and flow bench are you looking to obtain this "magic" number?
I've got one word of advice for you...
"COMBINATION"
Ed
Old 05-16-2004, 08:42 AM
SPANKY LS1's Avatar
EDC- Can you list some of your more successful LSx based "combos", both in ETs and dyno numbers?
Shawn
Old 05-16-2004, 10:10 AM
Shawn
I'm curious to see this as well, because personally, I have never seen any. Although, I would love to.
Old 05-16-2004, 09:02 PM
AINT SKEERED's Avatar
Shawn
True, I have seen great numbers from you with mustangs but Have not seen any thing out of you for the Ls1. Are you holding out on us or just not getting the results that you would like just yet? THis is not to start a flame just trying to see where you are at with the Ls1. I personally dont doubt your abilaty.
Old 05-16-2004, 09:07 PM
Josh, Ed is right about the combination though. My heads only peak at 262@.700and 257@.600 . They are not hogged out and I have good tq through the entire rpm range. You have seen my car and you know it is Heavy so dont let the biggest cam and Highest flowing heads cost you a lot of money because in the end, You know I am still gonna whip Ya
Old 05-16-2004, 09:50 PM
lol....... i got ya....... but I AINT SKEERED!!!!!!!! lol
Well I'm looking for something to go on a 6.0 litre. I chose the 320 mark plainly b/c I was looking at the absolute speed heads and they were like 2800 bucks and I'm assuming that is with a core. Of coarse I could have opted for the 330 mark.. but I'm not looking for the badest head on the market...... if I was I would go C5R...... but thats not in the plans for now and probably won't be needed anytime soon.
I'm looking for something that would perform well in a forged 6.0 liter, with something along the lines of a 234-238/240-244 duration camshaft. I'm just wanting to go a little different...... most people either do big cams and stock heads ort big heads and smaller cams........ I want to try a little of both worlds all in one combo.
Josh S.
Old 05-16-2004, 11:22 PM
LSX Mechanic
Damian's Avatar
My heads flow almost that much, cost about half of 3K....
BTW, peak flow #'s mean absolutely jack **** if low-mid lift #'s suck...
Old 05-17-2004, 10:27 AM
soo true!
Old 05-17-2004, 03:03 PM
racer7088's Avatar
Thumbs up
Well 320 cfm with a normal flow curve is a lot of cylinder head. You can run a "smaller" cam with it and make a more civivlized combination or you could use it on a bigger engine to make more power than you could with a lesser head. At least one combination I am talking about with heads in this ballpark went 9.60s so again that is a decent amount of cylinder head. I've seen 285 at .400 on some of these heads depending on chambers and valvejobs etc. with fairly normal valves so it all depend on what is being done.
Without knowing all the facts though you could have a 320 cfm head that was decent up high but had bad midlift and yet still went turbulent up too high. It also might be really really large and further reduce cylinder filling at lower rpms due to lower velocity than a comparable flowing yet smaller head could.
Basically I look for an appropriately sized head that flows great numbers for it's size both port size and valve size and has quality parts and is setup correctly for the intended usage and duty cycle that is expected of it. Anyone can do a worse or lesser job for cheaper, myself included. It's all about what is needed to get the job done and then some. If you don't "need" the airflow potential with the cam you are comfortable running then you will not see any big gains anyway.
We will soon be testing the smaller AFRs too because especially with the smaller heads and cams cars the smaller ports may help make more area under the curve. On an engine that needs way more air, like a 7500 rpm stroker, you will need more than 300 cfm probably to get the job done.
