From a 3.7 to a 3.4 Pulley how much more boost
Old 04-05-2014, 10:50 PM
LS2Ttype's Avatar
Default From a 3.7 to a 3.4 Pulley how much more boost
Thinking about turning it up, D1-sc with asters auto spring tentioner set up running a 3.7 now and making 15 psi at around 6,000-6,300 rpm
740rwhp
looking to swap out the 3.7 for a 3.4 and make some more power , any idea about how much more boost she would blow with the smaller 3.4 pulley?
Old 04-06-2014, 07:27 AM
stmz28's Avatar
I would buy a bigger crank pulley to help with belt slip and get you a couple more psi
http://www.cbrperformanceproducts.co...rib8.65ply.htm
Old 04-06-2014, 07:30 AM
helga203's Avatar
740rwhp
Every .1 is about a 1-1.5 lbs of boost so roughly 3 lbs ish. Is my guess.
Old 04-07-2014, 09:47 PM
LS2Ttype's Avatar
Nice!! 18 PSI would do the trick, Any idea how much more power i would make with 3 psi
Quick Reply: From a 3.7 to a 3.4 Pulley how much more boost
