traction issues
traction issues
right now i have stock 245 60 16 on the rear of my camaro. would going to a 315 35 18 bfg dr provide me better traction because of the width of will it be worse because of the lack of side wall? as always you input is greatly appreciated.
if you want a tire for racing/not daily driver look at the m&h racemasters www.intercotire.com the 305/40/16 musclecar drags pulled my front tires off the ground and i cut a i.59 60 foot(m6)they out hook et-streets and look better too,take alook. goodluck to ya.
i plan on getting some racemasters but that will be mainly for racing only. the 315's will be for every day use. hopefully i can use my first gear now. good 60' do you have any suspension mods to go with it?
yes. i have lca's,pan rod,fraim welded and tq-arm. i was cutting low 1.7's stock suspension, but it broke my stock tq-arm off the car,the m6 will do that. so...i up graded a little. the 1.59 was on 5-year old tires,i hope this year with my new tires i'll go low 1.5's or hi-1.4's(that would be nice)
i was told the 245-50-16 drag radial will perform as good as the 275-40-17 or 315-35-18 for drag racing (ie low psi). I guess the spiel was that the extra sidewall of the 245-50-16 , well its a lot of sidewall to flex versus a 40 or 35 series tire the latter having nearing no flex.
18's? sux when the rims cost less than the tires huh.
i'm buying iforged evolutions so i wouldnt know.
how is a 315/35/18 too big for an fbody? is it too tall or too wide? i ve seen people put this size tire on a big riim like the ones i plan on getting
naw i was just saying the TIRE COST sucks for 18's. i was about to get a set of z06 18's but then realized i'd be spending nearly a grand on tires (good fronts, drag radials in back). Plus all these damn cheap oem rims aren't built very tuff (bbs forged = strong rim).
Whats the actual sidewall height on a 305-40-16 versus a 315-35-18? I suck at math. Are you saying the 305-40-16 has nearly the same size sidewall as the 315-35-18?
The 35 sidewall would produce too much height, plus I dont even think a tire exists in that size.
Originally Posted by alexWS6
I think you mean 315/30/18, which will be fine depending on the wheel's offset.
