If you lean out a cylinder, you're going to have a bad time...*Carnage pics inside
It looks like we had an injector issue, or something to cause a lean condition on cylinder 4 and it got real ugly for our Magnuson supercharged/nitrous ls3 2010 SS shop car. We were trying for an 8.9x pass but instead it torched out the head gasket and partially into the head and block. Car still went 9.22 on this pass. This setup still did well for us for a few years, but looks like we found the limit of it. We are still hashing out what direction to go from here. Big cube n/a, turbo, or another roots style system. Either way, we will be back in action later this year with our multi-duty 5th gen!
We are suspecting some head lift due to aggressive timing. But it was isolated to this cylinder only. All others look fine. We kept it a little to the fat side to try to be safe. The piston and ring land appear to be intact so far, but we will tear down the bottom end to inspect it as well.
LS1Tech Premium Sponsor
From everyone we have talked to it appears that fixing the head and block wouldn't be too big of a deal but we just have to figure out what we are going to do with the car. We have talked about toning the car down a bit and throwing the 6 speed manual transmission and concentrating on more handling oriented stuff. We have a LS3/TR6060 pullout that we picked up for our 68 Pontiac GTO project car that we have thought about throwing in there but who knows.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
I would always have said detonation caused it.
But given how common this sort of damage is and sometimes on well tuned motors, it does seem that when head gasket integrity is lost, this is just what happens sometimes due to combustion escaping.
Given there is a liner involved I dont see how that block can be easily repaired without also replacing the liner.
The head definitely can be repaired though. Mine was far worse than that and Trickflow repaired my head. Block was scrap though.
Either way anyway, the motor needs pulled and pistons/rings inspected
With a thick composite gasket, the gasket usually burns away leaving the alloy barely damaged.
Because the MLS is more robust, the alloy almost goes first when gasket seal is lost, then combustion just blows it's way out like a plasma torch.
UNDER PRESSURE MOD
If anything I think MLS gaskets are helping the damage when it happens.
