Anyone interested in not having to remove the water pump in order to change the opti
This concept spaces the lt1 water pump off the block just enough to allow the optispark to be removed without having to actually remove the water pump. This obviously saves a LOT of hassle AND in spacing it away from the opti, allows a little more airspace around the unit, allowing it to potentially run cooler, and keeps the weep hole from weeping all over the opti in the event of a failure. Possibly the biggest advantage of this is the confidence to run your run of the mill parts store opti with a lifetime warranty and never have to pay for another again, without the hassle of draining the coolant system if/when it goes bad. Because of the nature of this mod, electric water pump users are probably not going to be able to run the spacers without some extensive trimming of the radiator fan shroud (I highly doubt a mezierre will fit, a CSR or jets unit MIGHT).
Basically this kit would include two CNC aluminum 1.25" spacers, extended bolts, two sets of water pump gaskets, and either a new or extended water pump drive coupling. Still working on gathering materials for production pricing, (and possibly a vendor to supply internally splined couplings so i don't have to weld an extension to the OEM coupling.... aka more money) so that is still an unknown at the moment but I'm looking at around $150 shipped (this is an ESTIMATE, not a final price!)
This being said, give me your thoughts and opinions on the concept and if you think this is a product you would be interested in.
Here are a few quick (and dirty) videos showing the installed water pump and the removal and installation of the opti to show that it works, and a pic of these beautiful spacers....
look here http://ltxtech.com/forums/showthread...hange-the-opti
posted for a friend
posted for a friend
That's not a bad idea I like it.. But I think it's a little over priced..
Wow, so much negativity from my LT1 brothers. Its nice hearing about a new item for the LT. I like the idea, it will make cap and rotor changes far more common, and will allow for on the road opti replacement.
Not seeing how you are going to get to the cap and rotor screws, even with a little more space. Certainly not with the common screwdriver like torx tool.
I screwed a Zerk fitting into weep hole. I used a small drill bit in the center first then screwed it in then ran a hose from the Zerk to just above the bottom of oil pan.
Thanks for posting this here Lloyd. I agree with you guys on the price. I was hoping to get it in the $100-$125 range. The $150 price is based off of the machinist doing one set at a time. He told me that if he does 10 sets I will see a price break. How much I don't know, but it will be passed on to the customer. I also agree that removing the water pump isn't a huge deal but I also hear the opposite from a lot of people that change their opti out, only to find they got a bad one right out of the box or it only lasts a few weeks. Then they have to turn right around and do the job again. With these spacers of f-bodies, I know a mezierre ewp will not clear, but I am looking into others to see if some trimming of the shroud will make it fit. I'm told that on B-bodies there is plenty of room. For ewp users that don't need the drive coupling, they would only be $125 shipped. Again, depending on how many orders I get this may be less. I am also going to order a few sets with holes drilled to be tapped 1" npt for an fittings for remote systems.That pricing would probably be the same. This is definitely a convenience item so I know the price may be hard to justify for some, but for others that have had bad luck in the past with optis will appreciate the fact it will only take 10 minutes to swap it out without a drop of coolant being spilled. Keep the comments comming. Positive and negative. I need to figure out how much $$$ i want to put up for this. Thanks.
Using some sort of remote electric pump with pipes plumbed out of something like those blocks would seem more beneficial and completely free access to the opti. Of course, that is probably just more complication.
I will be recieving the first set, so that I can get the Magna-TronX distributor proven out, It may have to come off a coule of times??? Of corse if this works, Ill have to decide which distributor to run but I suspect that decission has been made for me already?? I gotta have a working demo
I mentioned this in a thread at CamaroZ28.com: how hard it is to see what you are doing to line up the opti correctly? Your line of sight is compromised by the water pump. You can't just throw it up there and slap it on like the video shows and expect it to be lined up correctly.
I assumed as much and that it wasn't supposed to be an all inclusive video. Just trying to point out things as they come to me - not trying to be a naysayer. I applaud your efforts to create something beneficial to the LT1 community.
Neat idea. I had a TNT LT1 plate kit a number of years back and to get the plate to fit with my 58mm BBK TB I had to grind a lot out of the thermostat and IAC housing. I then bought one of the first LT1 plates from Nitrous Outlet, awesome plate but had the same issue. I believe they then made the plates thinner later on. With the spacers it moves the housing forward giving more space.
