When you hook, stuff breaks!
Went to the track last night (first time at this track, first attempt at a pass) did a good burnout on the Nitto's... Hooked like a **** and then clack clack clack clack!! Twisted the damn driveshaft. I honestly did not expect this to break so I have never really done research on it before. I've done a bit of looking now and a PST is way outta budget right now, but that's all I've found. Is it really either a stock used one for $100 or a PST for $300ish?! I would like to get something a little beefier than stock but $300 is out of range right now. Anybody got something a bit stronger than stock that won't necessarily murder my wallet? Didn't see much on running a Steel DS, anybody got experience with that? Also going to get a DS loop, looking at UMI/BMR any reason why one is better?
Carnage pic:
They hooked alright:
Carnage pic:
LS1Tech Sponsor
That's too bad, usually when they let go they put nasty punctures in the floor, and dent up the exhaust system. I don't know of anything cheaper than the PST 3.0" steel driveshaft, you might get lucky and find a used one. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
You're very lucky that's all it did. $300 might seem like a lot, but replacing a Trans, rear, exhaust, fixing a few holes in your floor are way worse. They can and will break much more violently than yours. Either spend the money on the Pst or hold out for a nice used one.
Daaamn!!
Looks like the TA has been cracking for a while. The fracture on the bottom is not fresh
FWIW, 3rd gens have a common steel DS as well. Narrower shaft, slightly thicker walls but almost all need a balance
Front and rear DS loops are always a good idea on the track and dynos
There is a company in your town which will make you one similar to a Denny's HD unit for cheap.
I bought a 3.5" diameter 56" long with new yoke installed and Spicer solid u joints for $230 shipped. High speed balanced, powder coated, and everything.
Blumenthal Manufacturing in OKC
