pump problems.
Old 04-13-2014, 04:37 PM
jleews6's Avatar
Default pump problems.
I just put a new pump in my wifes car because I thought the other one was dead but now Im wondering if its the pump. The car will idle but is a little rough and if i go to rev it,It will rev with very light throttle but if I try to give it more then a 1/4 throttle it just fall on its face.
I disconnected the fuel line at the filter and put the line in a gallon jug and when you turn the key on it just sprays a little and then stops. Isn't the pump supposed to stay running if there is no load on it?
Any ideas?
Thanks
JL
Old 04-13-2014, 06:45 PM
Old Geezer's Avatar
No, it's not. Unless the pcm sees rpm signal, the pump will just go thru the prime cycle, [what you saw], and shut off.
Old 04-13-2014, 10:06 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
Get a pressure gauge on the fuel rail & let us know what the pressure is under both conditions. This will determine if the fuel system is at fault.
Quick Reply: pump problems.
