Street Racing & Kill Stories Basic Technical Questions & Advice
MY 00 SS vs new C7 (vid)
Old 04-13-2014, 08:28 PM
necrocannibal's Avatar
Default MY 00 SS vs new C7 (vid)
Just happened to run into this guy cruising around. C7s are pretty impressive.
Old 04-13-2014, 08:47 PM
7 Second Club
islander033's Avatar
Good pull.
C7 wasn't that good, even the camera car drug his ***. Lol
Old 04-13-2014, 08:51 PM
HCI2000SS's Avatar
So you are just bolt ons only?
Old 04-13-2014, 10:29 PM
1997transamws6's Avatar
more details on your car?
Old 04-13-2014, 10:35 PM
big hammer's Avatar
y pipe only.
ASSuming On The Tree
audacious nick's Avatar
Either he has more than bolt-ons, or the c7 driver sucked. They trap between 116-120 stock.
Old 04-13-2014, 10:44 PM
big hammer's Avatar
so do bolt on ls1's...
when done right.
Old 04-13-2014, 11:15 PM
when done right.
Yeah, no. Stop trying to compare the heavily-modified(suspension and chassis-wise) unicorns to an average range. Most bolt-on LS1s will trap 110-112.
Old 04-13-2014, 11:54 PM
6PntHo's Avatar
Good run. Deff put a hurtin on him.
Old 04-14-2014, 01:27 AM
LS1rob00's Avatar
Nice kill. I'm assuming you have more than bolt-on's now pulling a car that traps 117-119 stock. What all is done to the SS? Is the C7 auto or manual?
Old 04-14-2014, 03:39 AM
4PointSlow's Avatar
I trapped 111-113 and i have the stock ls6 intake that came on 02's, oem throttle body, stock exhaust manifolds, stock y pipe, stock piping, and a stock stall(lighter aftermarket 245 mm single disc will pick up 1-2 mph).
I dyno'd 328 whp, with full bolt ons and a lighter locked stall it would easily do 360-370 whp. So I'll you figure out what it will trap. 115-117 mph in the same DA..
Temp rose 20 degrees from first pass to last pass(50 to 70). DA rose from 600 to 1600. So traps went down slowly. This is on Kumho Ecsta all season rear tires, 245/55r16. Not my drag radial setup(which are black prostars with et streets on them to match the front). If I had tire I would have done 12.2-12.3.
Intake/AED tuned/Drag radial/LCA's 2013 5.0 I raced(my 12.4 run). In fact when this pic was taken we were racing.
Old 04-14-2014, 05:45 AM
flattusmaximus78's Avatar
That fbody is burning a lot of oil.
Old 04-14-2014, 05:50 AM
4PointSlow's Avatar
All the OP's needs is an oil catch can.
Old 04-14-2014, 06:58 AM
5.0 vs LS1 - YouTube
4pointslow would pull a C7 in a stock 98 civic
Old 04-14-2014, 07:45 AM
big hammer's Avatar
he never specified what bolt ons he had. stop being dumb.
Old 04-14-2014, 07:56 AM
Gt4urass's Avatar
Strong Camero you have there sir, though, they all seem to be on this forum... Nice vid!
Old 04-14-2014, 09:09 AM
Thanks guys sorry for any confusion. The oil you see is because the oil restrictor isn't small enough, I am going to change it out sometime this week.
As for the car I just got it back from having a Precision 7675 put in. Its running on its initial break in low boost setting right now around 9 pounds. I am going to put up another video of me vs a H/C 427 C5Z, fast little ****** it was.
Old 04-14-2014, 09:32 AM
Blown383LS1's Avatar
Good run. It appears you and 4.slow would be a good race. Turbo vs. 3 bolt ons....
Old 04-14-2014, 03:21 PM
LS1rob00's Avatar
Cool, and your point is? Nobody cares.
Old 04-14-2014, 04:40 PM
No one asked you, troll. Just because a handful of LS1s have run a 116 in negative DA, along with all their other suspension mods, doesn't mean this one is going to run the same.
I want to see you against a stock c7, so we can lol
Quick Reply: MY 00 SS vs new C7 (vid)
