4L60E not Shifting from 1st to 2nd
I have a 2000 camaro that just hit 111k at about 106k I had some mods done cam, heads set up, timing chain, ETC... And I put a Edge 3400 stall in a 4L60E A4. Now yesterday when I was in Drive at the Stop sign I went to drive off but it didn't want to shift into 2nd gear and my speedometer was reading 0mph when I was going it took awhile to shift, and also when I'm coming to stop but I let off the brakes there's a loud clunk any ideas on both problems, Thanks
Vehicle uses speedometer input to command shift points. Its possible the trans is in backup mode which would command late and/or harsh shifts Check your connections at the vehicle speed sensor. If your connections are good you will need to replace the vss.
Moderator
