Gears & Axles - limited slip???
View Full Version : limited slip???
swampfox25
05-15-2004, 06:44 PM
Ok im not sure if it goes here but I have a 1990 chevy 1500 with a 2000 Ls1 in her =-)
My question is... I have an aftermarket limited slip rear end and For some reason it seems to just act like a normal differential. When I try and test it by trying to spin the tires alittle the right tire spins and the left doesnt even try to budge any causes ??? Thanks guys
goinbroke
05-15-2004, 11:06 PM
Mine does the same at the track on a burnout. Only the right tire will spin. I was told that the clutches in the rear are shot. Anybody else?
swampfox25
05-16-2004, 11:08 AM
What can I possibly do to fix it?
swampfox25
05-17-2004, 07:51 AM
No one??
TheMightyWS6
05-17-2004, 09:42 AM
if it's a rebuildable limited slip, get a limited slip rebuild kit. i know you can get that stuff for the eaton posi. not sure about others.
