Boost referenced pressure regulator install help
That's how most people setup there system. However using the ls6 rail there is not where to pick up a return aside from the Schrader valve...Then you have to try and hide everything right in the front of the motor...I think this will be a cleaner install and I can't see where there would be that much of an advantage either before after the rail...maybe some but in that short of a distance I doubt the pressure drop will be that substantial. This is just a 5.3 looking for 520+
You mean like if they scan your car?? Set the evap to not reporting and the computer will no longer recognize the code. If you just turn the light out the obdII scan will still pull it...I'm in WV though so as long as it arrives and departs under its own power your good to go!
