Head Gasket Recommendations
Old 04-17-2014, 01:47 PM
3rdgentug's Avatar
Default Head Gasket Recommendations
408 iron block - s480 ect...
the heads Im running are TEA stage 3 blower heads that have been o-ringed for boost.
I was informed to not use an MLS gasket since they are o-ringed and would not seal properly.
I was suggested to use Fel-PRO PT9199 - but after doing some reading up on them Fel-Pro states to not use these in high boost applications.
So here I am asking for suggestions.
Old 04-17-2014, 02:48 PM
Baconz28's Avatar
Guys seem to like the ls9 head gaskets
Old 04-17-2014, 02:50 PM
3rdgentug's Avatar
LS9 is an MLS gasket, was told I cannot use it.
Old 04-17-2014, 02:51 PM
yenkomike's Avatar
i have not seen many composite gaskets for ls engines that were not just rebuilder cheap gaskets.
Old 04-17-2014, 03:01 PM
3rdgentug's Avatar
That's my problem in a nutshell. I don't want to cheap out on head gaskets and have to replace them down the road anytime soon.
Old 04-17-2014, 03:33 PM
toytech93's Avatar
I'd recommend some copper gaskets, call the guys at SCE. (661)728-9200
Old 04-17-2014, 03:37 PM
SMOKNSS's Avatar
Why is that? I have put MLS gaskets on every LS motor I have ever worked on and never had an issue with them.
On my old nitrous motor I even sprayed the MLS gaskets with that copper spray and reused them.
Old 04-17-2014, 04:20 PM
rotary1307cc's Avatar
Jesus read the thread
He has receiver grooves cut
Old 04-17-2014, 05:14 PM
3rdgentug's Avatar
Thx , I'll look into that
Old 04-17-2014, 05:15 PM
3rdgentug's Avatar
O-ringed - they will not seal with an MLS is what I was told by people with way more knowledge then myself.
Quick Reply: Head Gasket Recommendations
