BW S475 Burning and Leaking Oil from Downpipe.....
Borg Warner S475 turbo, -4AN feed and -10AN drain into the pan above the oil. No bends in the return line greater than 45* and even those are just the AN fittings coming out of the turbo and then going into the pan. Turbo is mounted high on the front driver side. Feed and drain are perfectly straight up/down.
Still trying to get the wrinkles ironed out before heading to the dyno and my luck turns South again. Yesterday after getting to temp the downpipe starts puffing blue smoke at idle, even worse when reving. I shut it down and within mins there is a small puddle of oil about the size of a baseball under the downpipe on the garage floor. Even when already warm the smoking doesn't start for a few mins after the engine is started/running.
The odd part it I have had the engine running with the turbo for the last 2 weeks, maybe 30-45 mins of combined idle and reving under 4k and this is the first time it started smoking/leaking. No load or drive time at all other than pulling into the driveway from the garage (20'). Never once has it even made a single pound of boost. Oil pressure is 50 psi cold and drops to 40 psi when at 180*. Running 5w-30 oil.
Some local guys have suggested I run a 1.5mm restrictor, but BW doesn't say to do that.
At this point I am at a loss and almost ready to give up.
Any help is welcomed and thanked in advance.
My pressure and feed size are the same as yours. Same oil too.
I just checked for you and my restrictor size is .125".
I got no guidance on that, some said run no restrictor, run smaller etc.
That said, mine was the same way. Drove all over for 2 weeks, not a puff. Stopped for gas, bs'd with the station guys for a bit, pulled out and went 2 blocks and my car looks like a smoke machine.
It quit very quickly and has not smoked a puff since.....
I did readjust my return line slightly as it had moved and was going uphill a slight amount.
Don't give up. Maybe pull the drain off and make sure it's flowing? Drive some more and see if it quits?
BTW, too much oil is better than not enough.
Ron
Ron
I ran -4 feed and -12 return. When turbo was new and I first started the car it took several short spells where it would leak a good bit of oil into the downpipe. After a few good street cruises I guess it broke in and sealed up lol. It had me worried for a few days but its been fine ever since.
Ran it today after pulling the PCV filters to comfirn they arent the issue. Started it up and just like last time it starts smoking after getting to 140 degrees or so.
I pulled the drain tube this afternoon and its perfect. Next I pulled the downpipe and its soaked and coated in burnt oil inside. Then I pulled the whole turbo and it is leaking a small amount on the compressor side too.
I called Bullseye Turbo and they suggested I send it in for inspection and possible rebuild. Its being shipped out to Bullseye on Monday.
You should leave it on and run it at least a few street runs. Mine (s475) did this and it stopped after about 3 or 4 trips driving it around. It would be fine then just still blowing oil out. Looked like a train going down the road. I just drove anyway and it stopped on its own. I know its odd but its almost like it needed to heat cycle a few times to seal off completely.
I finally got the guy who sold it to me to respond to my msgs. Turns out it wasn't new, he ran it for 'a couple thousand miles' on his previous toy (6.0 LQ4 powered Camaro) and had it cleaned before posting it for sale. It definitely fooled me because except for some minor surface rust on the turbine housing, it looked great. He said it never leaked or burned a drop of oil, but since he already lied once, I wouldn't believe him if he told me rain was wet.
I guess I should of known better since I got it for less than half of retail price, but it's done now.
Moving on.....
Now that we know that the turbo isn't new and has an unknown history, now what?
I still find it odd that it didn't smoke/leak at first with me and then started.
Moving on.....
Moving on.....
Moving on.....
I'm going through the same thing with a new s476r. -4 feed, -12 drain, even tried a .060 restrictor, no difference.
Smoked from day 1 on the dyno, puked oil from the cartridge and exhaust wheel.
Martin and Jose are taking care of it.
You may want to look into larger drain while your at it.
Check the ID of the drain on the turbo itself. It’s close to ¾" for a reason. Typical ID of an AN10 hose is .56" or so. Most of the fittings ID’s are much smaller. (esp cheap china junk and push on fittings).
I believe Airworks/BW suggest 19mm minimum ID drain lines. Not that some don’t get away with less…
What are you running for an oil pump? I have a ported LS6 with a high pressure spring in mine, not sure if it's partially to blame or not.
