MWC TA install help
MWC TA install help
I've got the long TA with the trans crossmember. The old TA mount is in the way of the pivot. Does this whole part of the mount come off, or do I need to break the rivets and remove the rubber piece, or am I just doing something else completely wrong?
So after looking around, I realized I'm an idiot. I overlooked the nut on the other side holding the exhaust hanger, so now it's just hanging loose. Now the issue is how do I get it off? Does the whole tailshaft have to come off to get this off?
LS1Tech Premium Sponsor
If you are having contact with the speed sensor then the torque arm front heim is adjusted too far out, or the wheelbase adjustment is too far forward. You can rotate the sensor 90 degrees as well to help if need be- removal not required to do so. The link barely moves during suspension travel.
